HELP!!!
Discussion in 'Body Restoration' started by bucko2855, Feb 28, 2018.
  1. bucko2855
    bucko2855 New Member
    17
    Aug 20, 2016
    Waterdown,Ontario,Canada
    Okay you can laugh first and then help me. Newer at doing a Camaro restoration and I've done everything by the book until now..........I have taken pictures and labelled MOST of my parts however for the life of me I cannot recall where this goes.
    Its a 1977 Camaro Coupe with no A/C and the restoration is the dismantling of the entire front end back to the firewall. The piece is a small piece of sheet metal that has bent edges, with 2 holes (for fastening i assume) and i thought it may have come from the right fender area close to the heater box.
  2. Twisted_Metal
    25,754
    444
    IIRC, that’s a heat shield which bolts to the frame near the catalytic converter.
  3. bucko2855
    17
    Aug 20, 2016
  4. bucko2855
    17
    Aug 20, 2016
    That may be why I can't find its location since the subframe is still out getting older coated. I couldn't find it in the manuals at all but i was focusing on the fender/firewall area.
  5. MotionClone
    MotionClone Veteran Member
    1,462
    270
    Jan 20, 2014
    away from the crazies
    Thats the shield that mounts to the side of the subframe and protects the rubber portion of the fuel line....I believe
  6. bucko2855
    17
    Aug 20, 2016
    going t manuals now to see if i can find it guys, fingers crossed
  7. bucko2855
    17
    Aug 20, 2016
    gents thank you very much, now labeled for when i assemble!!
