Help with Compressor Hard Line ideas
Discussion in 'Garages, Workshops & Tools' started by Codemonkey17, Apr 11, 2016.
  1. CasperCasper
    CasperCasper Veteran Member
    994
    106
    Aug 11, 2015
    Remember that you cant pull water out of the lines immediately after the compressor. The water takes time to condense out of the cooling air. I have 50 feet before my water trap. It looks god awful as the hose runs up the wall and zig zags down. The air is bone dry however!
  2. 70lt1z28
    2,250
    319
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Actually, you CAN pull water out of the lines right after the compressor. It is called an aftercooler and works pretty good as it keeps the water out of your tank. It takes some money, but not too much if you buy the stuff on eBay.
    Here is a link to my compressor:
    http://www.garagejournal.com/forum/showpost.php?p=6233978&postcount=41
    And the results:
    http://www.garagejournal.com/forum/showpost.php?p=6235197&postcount=50
    The air going into my tank is ~ 5 degrees above ambient.
    Pulls out about a cup of water an hour at 35% RH. Probably will at least double that in humid conditions.
    Much of it depends on what you want to do with your compressor. I want to shoot paint and run a blaster and for that you need very dry air. If you are just running air tools and don't mind trashing them over time, you can get away with much less.
    If you want to just buy one without fabricating anything here is a link:
    http://www.castair.net/after-coolers.html
    good luck.
  3. Bandit723
    Bandit723 Veteran Member
    2,663
    325
    Oct 1, 2016
    Waupaca WI
    If you can swing it the after cooler is the way to go. I went with a homemade solution, cost me about $200.00 to put together. It's not pretty but does work. for painting I use a decadent filter to make sure I catch any moisture.
  4. DB Z28
    DB Z28 Veteran Member
    531
    32
    Nov 30, 2003
    Fond Du Lac
    Don,t forget to Add your automatic drain kit Works well from Harbor freight for 9.99 keeps the water out of your tank
