help on window flush fit ?
Discussion in 'Tips 'n' Tricks Topic' started by Twisted72, Nov 17, 2015.
  1. Twisted72
    Twisted72 Veteran Member
    298
    41
    Nov 8, 2015
    New Albany, Indiana
    has or does any one know bout doing away with the window molding front and rear to make it flush fit ?
  2. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    No glass available that I know of for such a thing.
    I've see first gens done but they paid up the wahzoo for custom glass.
    Unless you happen to be great at welding then you could just close the gap up a bit and find a rubber seal that works. Either way it's a ton of work!
  3. EeeZee73
    EeeZee73 New Member
    21
    Oct 30, 2016
    Good afternoon/ evening depending on what part of the country you are in. There is company in Arizona Fessler.com check them out. The set of front and rear cost approx 1,400. Thanks
  4. Twisted_Metal
    25,994
    511
    Shopfesler.com
    Is the correct name.
    $1500 for the kit.
  5. jimrr
    jimrr Veteran Member
    1,231
    276
    Jun 12, 2016
    sarasota
    Someone here used the stock front and rear windows with the newer style rubber\plastic window channel used on newer cars. Came out perfectly. He listed the extra in the for sale section. If search the correct words in the for sale section you might find it and see his finished Job. It looked fantabulous! I'd search windshield and molding in the for sale section. It was at least a couple years ago he listed it..... HTH
  6. cadillac_al
    cadillac_al Veteran Member
    648
    45
    Apr 22, 2015
    Maine
    Ewww, that looks better than molding? I'd say it's definitely a personal preference thing.
