Help on rear end
Discussion in 'Transmission & Driveline Topics' started by hogg, Mar 4, 2018.
  1. big gear head
    big gear head Veteran Member
    5,986
    25
    Jul 30, 2001
    Central City, Ky.
    Your Camaro has a 8.5 rear end, not a 10.5.
    If you remove the ring gear from the differential it will be a lot easier to remove and install the S spring. I use Channel Locks to compress the spring and push it back in between the axle gears. Tory has new clutches and shim sets for the 8.5 Traction Lock differential. Set up the clutches just like the Eaton Posi. The Tom's Differentials video explains how to shim them.
  2. Green hornet
    Green hornet Veteran Member
    1,257
    183
    Oct 11, 2015
    North Bay, CA
    I purchese new clutches for my posi from Troy last month. Really good product and really nice guy.
  3. hogg
    hogg Veteran Member
    3,143
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    Ok, finely got around to taking apart the clutches and gears, the ring gear looked new,stamped 1 GM 3984831 12 41 7 73,? Housing stamped, 410408n GM 5 J 2 0 10 2 70 . All this look right for 74 8.5 10 bolt? The S spring shows some ruffnes where it had been trying to move a little.The clutches look worn some , 3 with teeth each side,4 with out teeth with stops or what ever, and 1 thick shim each side,090 ring gear side and 1 thick shim washer .094 other side . Could i put a shim on each side to take up some slack, If so how do i tell how much and where? Am going to buy new spider gear washers for under gears and pin,all new bearings ,and pion bearings and crush slive. I should put in new clutches but this just going to be a driver for grand son. Am cheap old s**,,, Thanks, So much,for you guys input,, camaro 71/hollan,, Big gear head,,Green hornet,,djorgensen3 thanks all
  4. camaro71/holland
    968
    29
    Aug 27, 2003
    The Netherlands
    No problem. This should get you there:
  5. big gear head
    5,986
    25
    Jul 30, 2001
    Central City, Ky.
    Tom's video shows how to set up the clutches for the Eaton Posi, but it works for the Traction Lock too. The problem with the Traction Lock is that GM never offered any shims for the clutches. Tory makes shims for it, but I don't know if he sells them without the clutches. I don't think you can get thrust washers for this differential.
  6. hogg
    hogg Veteran Member
    3,143
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    Is the 8.2 open rear spider gear washers the same, got a few of them laying around ?
  7. slayer021175666
    slayer021175666 Veteran Member
    1,212
    57
    Feb 29, 2016
    Idaho
    Can't see your pics. It says 3rd party hosting has been temporarily disabled. Am I doing something wrong?
  8. big gear head
    5,986
    25
    Jul 30, 2001
    Central City, Ky.
    I can't see them either. I'm pretty sure that the 8.5 Traction Lock washers are different from any others.
  9. hogg
    hogg Veteran Member
    3,143
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    Thanks all, am slow. can't get the pion nut off. will have to wait for son to try, first time the impack gun has failed me. later
  10. MotionClone
    MotionClone Veteran Member
    1,462
    270
    Jan 20, 2014
    away from the crazies
    Yeah you need like a 6' cheater bar. Cant remember the torque spec but its a lot.
