Help. Just picked up a 1970 camaro Parting out
Discussion in '1970 - 1973 Specific' started by thomer, Dec 2, 2017.
  1. thomer
    thomer Veteran Member
    108
    Sep 13, 2009
    ohio
    I know there are several 70 only parts on this car and dont want to many anything. The car was grey black vinyl top. 307 auto on the column car but its to bad to save. So I am stripping what I can and want to be sure I dont miss anything. Its to bad as its a numbers matching 307 car which isnt much, but lets be honest. that 307 in 70 had more HP than the z28s did in 80 and 81. LOL
    SO if anyone would help me to insure I dont miss any parts I need to be pulling from this car Id be grateful.
    Thanks.
  2. 70lt1z28
    1,570
    173
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Whereabouts in Ohio?
  3. thomer
    108
    Sep 13, 2009
    ohio
    Just north of Dayton.
  4. 70lt1z28
    1,570
    173
    Oct 3, 1999
    Mind if I come by and take a look at what you got? I'm in Beavercreek
  5. thomer
    108
    Sep 13, 2009
    ohio
    Not at all. But its ROUGH! LOL
  6. 70-camaro
    70-camaro Veteran Member
    1,067
    108
    Mar 25, 2010
    marietta ohio
    How does the trunk emblem look? Any pics? Also would like a heater hose holder that is on the right fender well.
  7. McCune
    McCune Veteran Member
    703
    66
    Aug 22, 2015
    st.george utah
    No, the 307 did not make more power than the LM1.
  8. thomer
    108
    Sep 13, 2009
    ohio
    I am only going by the specs posted on this site. The 307 with a 2 barrel makes more power than the 81 LM1 per the spec sheets. Speaking motor itself. Not the rest of the power train. More compression, higher torque. So what am I missing here if your claim the LM1 made more power in 81 than a 70 307?
    LG4/Z28 305 V-8 3.74 x 3.48 165 @ 4000 245 @ 2400 8.6:1 4V
    LM-1 350 V-8 4.00 x 3.48 175 @ 4000 275 @ 2400 8.2:1 4V
    Base 307 V-8 3.875 x 3.25 200 @ 4600 300 @ 2400 9.0:1 2V
  9. McCune
    703
    66
    Aug 22, 2015
    st.george utah
    The 70 307 HP rating is (Gross) at the flywheel and the 80 Z28 is (Net)to the rear wheels. In 1971 the Z28 had a advertised HP of 330 gross HP and in 72 the same exact engine was rated net at 255, both engine made the same gross HP.
    All Chevy engines changed to Net HP in 1972.
  10. Turbo70Camaro
    2,041
    89
    Jan 7, 2005
    so cal
    Hay bud I'm looking for the big ground terminal that attaches to the backside off the cigarette lighter (large ring terminal with ground wire).
    Thanks
