Help Identifying A Front Splitter
Discussion in 'Body Restoration' started by __Z__, Aug 19, 2017.
  1. __Z__
    __Z__ New Member
    Aug 19, 2017
    Anyone have any clue what front splitter/chin spoiler this is?
    Thx guys,
    Z
  2. garyandcindy
    garyandcindy Veteran Member
    1,603
    Oct 20, 2004
    cumming,ga-usa
    Looks like a custom fabbed piece to me.
  3. Double R Restorations
    2,700
    47
    Jan 11, 2002
    VA
  4. __Z__
    __Z__ New Member
    Aug 19, 2017
    Well that's a shame, was hoping I could find one similar off the shelf.
  5. Zspoiler
    Zspoiler Veteran Member
    2,889
    184
    May 6, 2012
    Federal Way, Washington
    Or fabricate your own.
  6. __Z__
    __Z__ New Member
    Aug 19, 2017
    I draw my my metal fabrication line at patching panels. Based both on tools and skill ha.
  7. NOT A TA
    NOT A TA Veteran Member
    198
    53
    Feb 12, 2009
    Delray Beach Florida
    That's an air dam, not a splitter. It looks like someone did a nice job contouring it to the body etc. but it's more show than function by the looks of it. I'd be afraid to go over 90MPH or so with it. Doesn't appear to have any supports behind the ends (although maybe there are some) and the outward supports to the splash pan appear to be too straight up to keep pressure from flipping them back, among other things. There is a LOT of force once you start getting up to high speeds. If you can push that back with your foot there's gonna be problems at speed.
    I'm currently working on an experimental quick release splitter/under tray/rear diffuser combination for 2nd gen F bodies. I'm building it for a TA but it could be used on any 70-81 F body with an appropriate air dam. Once I get the aero stuff all tested I'll make much lighter more finished looking versions. This version is for test purposes only. More info about it here https://www.linkedin.com/post/edit/...ully-suspended-multi-section-quick-john-paige
    __Z__ likes this.
  8. zachary8
    zachary8 Veteran Member
    221
    Jan 22, 2012
    Chicago, Illinois
    Kudos> Wow!
