Help identify motor
Discussion in 'Troubleshooting & Diagnosis' started by Jamese279, Aug 8, 2017.
  1. Jamese279
    Jamese279 New Member
    Aug 8, 2017
    Pad on motor has been machined so VIN is gone. But I have the following:
    Block: 3970010
    Block Date Stamp: C69
    Heads: 3927186
    Heads Date Stamp: I69
    Crank: 3932442
    4 Bolt Main
    I've narrowed to a 350 but don't know it's 300hp or 350hp? Also, what vehicle was it used in? Thoughts?
  2. Gary S
    21,442
    412
    You need the engine code stamped on the front pad to identify it. Without that, you can look at the valve size. 300hp would have 1.94 and 350hp would have 2.02. Also, the pistons are different. 300hp had flat top pistons, 350hp had dome pistons. But, if the block has been decked, the original parts might no longer be in the engine.
    The numbers you posted only tell us that it is a 1969 350.
  3. Jamese279
    Aug 8, 2017
    Well it does have 2.02 valves so I guess that makes it a 350HP. What vehicles were these used with in '69?
  4. 70lt1z28
    2,476
    365
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Corvette only had the 350-350. It would be a 4 bolt main also.
    Block and heads dates are too far off to be original to each other. Due to this, the heads may have had bigger valves fitted or be from another engine. Do the pistons have domes or are they flat? They could be changed out also.
  5. Jamese279
    Aug 8, 2017
    Domed pistons are what it currently has. So with what we know does a 750cfm carb make sense?
  6. Gary S
    21,442
    412
    Originally the 350hp 350 had a quadrajet that flowed around 750cfm, so as long as it is a vacuum secondary 750, it would work just fine.
  7. 74BIBELOT
    74BIBELOT Veteran Member
    What about crankshaft? It's a cast one?
  8. Jamese279
    Aug 8, 2017
    Yes. It is cast (#Crank: 3932442)
  9. 74BIBELOT
    Everything looks good except the crank, as Gary said look for the engine code, also try to identify the rods, timing cover , camshaft.
    I am agree with 70lt1z28 about heads/block dates 6 month apart.
  10. jbloake
    jbloake Veteran Member
    280
    44
    May 1, 2002
    Atlantic Canada
    Is there a Vin# near the oil filter. That would tell you what factory the block was installed
