Help finding a 1974 camaro gas tank sending unit (2 lines)
Discussion in 'Camaro Questions' started by Sparx, Apr 7, 2008.
  1. Sparx
    Sparx Member
    65
    Jul 20, 2007
    Nebraska
    I need some Help finding a 1974 camaro gas tank sending unit (2 lines). my gauge don't work, and I've kinda narrowed it down to that. I stopped by advance auto parts and in ten days they can get one for a 1976 (74 isn't available) I think 76 is the same. 73 camaro had a 18 gallon tank & 74 had a 21gallon tank. Advance wants $116.00 can I get one sooner and cheaper some where else ?
    thanks
  2. ejpii
    ejpii Veteran Member
    246
    Mar 10, 2008
    Northeast
    81 Z28 has a 21 gal. tanks and a 2-line sender.
    EJ
  3. Sparx
    Sparx Member
    65
    Jul 20, 2007
    Nebraska
    any other help ?
    thanks
  4. krabben1
    8,053
    May 16, 2007
    ( . Y . )Delco
  5. FIREDUP71
    FIREDUP71 Veteran Member
    351
    Dec 21, 2006
    CONNECTICUT
    try inline tube - they should have it
  6. FIREDUP71
    351
    Dec 21, 2006
    CONNECTICUT
  7. Kamikaze
    Sparx,
    PM Sent.
  8. Sparx
    Sparx Member
    65
    Jul 20, 2007
    Nebraska
    I emailed gastanks.com, thanks FIREDUP71, as I just emailed http://www.inlinetube.com/
    I will see what they say.
    thanks evveryone
  9. Kamikaze
    Sparx,
    Message received...
  10. MadMike
    MadMike Administrator Staff Member
    13,561
    32
    Feb 11, 1999
    Dawsonville Georgia
    A word of caution...
    The sending unit hole on a 1970 - 73 tank is larger than a 1974+ hole.
    So if I list a sending unit for "1970 - 75"... somethings wrong. Cause it won't fit in a 1974 or 5 tank.
    The tank changes in 1974, with the trunk floor.
    Here's what happenes when you use a 1976+ sending unit with a 1974 line:
    http://www.nastyz28.com/~madmike/74z28/line-snafu.jpg
    I knew this would be the issue prior to getting into it and will "recontour" the fuel lines to be closer to where they both expect each other to be.
    I compared the new stuff against my old stuff. The 74 line stops in front of the tank... it doesn't wrap around like depicted in the picture.
