Hedman Header 66104 Clearance
Discussion in '1970 - 1973 Specific' started by woodpeeler, Apr 24, 2017.
  1. woodpeeler
    woodpeeler New Member
    Jun 27, 2010
    Minneapolis, MN
    I broke out my torch and hammer and got quite a bit more clearance. We will see how it works out... IMG_2547.JPG
  2. Green hornet
    Green hornet Veteran Member
    1,310
    192
    Oct 11, 2015
    North Bay, CA
    Now that's making some room!!
  3. 70 SS/L78
    2,518
    56
    May 5, 2005
    Rockford, MN
    That's a great video on header bashing, never expected results like that! Seems like you can dent them within reason and have little or no effect on performance!
    If you have good motor mounts your engine will move very little in the exhaust area. The farther you get away from the motor mounts the more movement there will be. For example, your air cleaner will have more movement than your exhaust manifolds.
  4. Zspoiler
    Zspoiler Veteran Member
    2,674
    157
    May 6, 2012
    Federal Way, Washington
    Just get the correct headers.
  5. kyles73
    kyles73 New Member
    Mar 20, 2011
    SE Michigan
    I had to do the same thing to mine. Fit was great everywhere except for the damn control arm mount. I ordered mine uncoated as I fully expected some massaging was needed.
  6. Zspoiler
    2,674
    157
    May 6, 2012
    But if you do have do it .you just have to modify just slightly and some time what is causing the problem.Other wise you will have exhaust flow issues.
