heater core leaking
Discussion in 'Tips 'n' Tricks Topic' started by 1970whitess, Jun 9, 2015.
  1. 1970whitess
    1970whitess New Member
    16
    Nov 11, 2010
    pottstown ,pa
    getting anti-freeze on passenger carpet
    read article on replacing heater core at the top of article it said you could jump the liners .what does that mean and what type of fitting is needed to do that .I think the pipes are different sizes. could it be and else beside the core
    need help thanks
  2. COPO
    16,052
    201
    Don't know what that means, never ever heard of that. If you have water inside then the core needs no be replaced. You can still drive the car if you connect a hose from the water pump to the intake which bypasses the heater core.
  3. 1970whitess
    16
    Nov 11, 2010
    pottstown ,pa
    thanks mark
    what do you mean if you connect a hose {what hose ] from the water pump
    do you mean disconnect from water pump to intake of the pump which.
    or do you mean disconnect both pipes from core outlet and connect together
  4. Twisted_Metal
    25,458
    348
    I used a piece of copper tubing and hose clamps to splice the two hoses together. (Yes, they are different sizes.)
    Don't worry about reaching the hoses at the firewall end. You can cut them off in a convenient place for your splice because you should replace the hoses along with the heater core. (When you get around to it.)
    Good Luck!
  5. 1970whitess
    16
    Nov 11, 2010
    pottstown ,pa
    what size pipe did you use
  6. COPO
    16,052
    201
    In the past I've just used the largest of the 2 heater hoses. But
    if you want it to look nice, just go to an Auto store and get a foot
    of heater hose (the larger of the 2).
  7. Twisted_Metal
    25,458
    348
    1/2" ID(IIRC) copper tubing and a couple of hose clamps.
    It will be tight in one hose and a little sloppy in the other but the clamps will seal it up.
  8. 1970whitess
    16
    Nov 11, 2010
    pottstown ,pa
    if I buy a foot of 3/4 hose ,that will not fit over the 5/8 hose to clamp with
    a hose clamp plus the hose will probably kink.
    i'm not real smart when it comes to auto work, but I have to take care of this
  9. 1970whitess
    16
    Nov 11, 2010
    pottstown ,pa
    thanks twisted metal
  10. JKC
    JKC Veteran Member
    104
    Jul 12, 2014
    Knoxville Tn
    go to a parts place and get a 1/2 to 3/4 adaptor take the hose off the water pump and the intake and hook together top off with coolant or water and go.
