headers that fit
Discussion in '1977 Z28' started by VT Old Guy, Jun 22, 2015.
  1. VT Old Guy
    VT Old Guy New Member
    8
    Dec 17, 2011
    Burlington, VT
    I am trying to find a set of mid or shorty headers for my 77 Z28. Since it has been lowered with a Hotchkiss suspension I have clearance issues with the current long tube set.
    I plan on installing a new flowmaster exhaust but every set I look at says it will only work with an automatic mines's a 5 speed Tremec
    If you have any suggestions I would really appreciate!
  2. BonzoHansen
    My American racing headers fit great. But they are long tubes. I run a larger T56 and hotchkis tvs
  3. JWZ28
    JWZ28 Veteran Member
    1,238
    Feb 27, 2011
    Alabama
    Where are your clearance issues specifically? I'm running long tubes on my 78 with a BW ST-10 4 speed with no issues. I've lowered mine 2 inches all the way around.
  4. VT Old Guy
    8
    Dec 17, 2011
    Burlington, VT
    Been told by Hedman the cross shaft will be the issue...I was also told by FLowmaster
  5. BonzoHansen
    cross shaft? you mean the z-bar for the clutch?
  6. VT Old Guy
    8
    Dec 17, 2011
    Burlington, VT
    yes....most suggested I need a Hyd Clutch to be 100% certain there wil be no clearance issues.
  7. APEowner
    APEowner Veteran Member
    646
    11
    Dec 9, 2013
    Albuquerque, NM
  8. BonzoHansen
    i assumed SBC in a 77 Z28. A lot of headers ought to clear the z bar. The crappy hooker super comps i had did, i think the hedmans clear find, you can search the forum for headman and get details. Changing the trans does not change the z-bar mounting at all.
    My ARH clear the z-bar plenty.
  9. Zspoiler
    Zspoiler Veteran Member
    2,837
    178
    May 6, 2012
    Federal Way, Washington
    What are you specifically do with with the car.big tube small tube.I run a set of Flow Tech header on my 1981 El Camino SS with small block chevy .I have a 1979 Z-28 RS Camaro. With Doug Thorley big tube headers .Both are Pro-Touring cars with 3 inches of ground clearance.The frames are similar So maybe Flow Tech may have a set for your car.Wouldn`t hurt to check.
  10. VT Old Guy
    8
    Dec 17, 2011
    Burlington, VT
