Head questions
Discussion in 'Camaro Questions' started by Docs Motorcycle Shoppe, Jan 2, 2018.
  1. Docs Motorcycle Shoppe
    Docs Motorcycle Shoppe New Member
    Dec 16, 2017
    Mt. Ulla
    I have a 305 all stock..I found a set of 416 heads but they've already been worked .500 springs and bigger valves. My question is can I use these without putting a new cam in or will I need to put moor money in the bottom end to ?
  2. CorkyE
    9,527
    263
    Just in my opinion, that head, or any other head is not a bang for the buck deal with a 305. Save your money and buy a 350 based engine, they're very reasonable for the HP vs the dollar spent.
    BTW, welcome to NastyZ. :)
  3. RS1979
    3,080
    420
    Jun 18, 2013
    Memphis, TN
    I agree with Corky. The 350 has more HP potential than the 305. Drive the 305 while you build the 350.
  4. larrylarry
    larrylarry Veteran Member
    1,510
    67
    Dec 22, 2011
    San Antonio Tx
    Yes you can use that head but I’d check the valve to piston clearance unless the pistons are dished a lot. Flat top pistons I’d check, dish pistons maybe not.
  5. cadillac_al
    cadillac_al Veteran Member
    645
    41
    Apr 22, 2015
    Maine
    I wouldn't mess with a good running stock 305. I would invest in a 350 if more power was needed.
