Guys with LED turn signals... what electronic flasher are you running?
Discussion in 'Electrical Systems' started by ULTM8Z, Apr 26, 2010.
  1. ULTM8Z
    ULTM8Z Veteran Member
    8,890
    232
    May 19, 2000
    Los Angeles
    I'm about ready to complete my front light project. Wanted to know what electronic turn signal flasher has been proven on our 2nd gens.
    Thanks.
  2. jroach
    jroach Veteran Member
    1,284
    Apr 9, 2007
    petersburg MI
    why not use the stocker?
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I haven't bought mine yet. I'm just going to grab whatever Autozone offers.
    LED's don't draw enough current to trigger them properly.
    You need a special electronic flasher.
  4. ULTM8Z
    8,890
    232
    May 19, 2000
    Los Angeles
    I have a Tridon EL12 electronic flasher that I bought from Pep Boys, but the darn thing doesn't work. Not sure if I simply bought the wrong part... was wondering what other people are running.
  5. ozchevy
    ozchevy Veteran Member
    113
    Sep 6, 2007
    Sydney Australia
    Hi guys,
    One thing you will notice if using the stock flasher with LED turn signals - is that the lights will flash twice as fast as usual.
    This is because the LED's are a diode in the usual sense of a diode and utilise a resistive flow of electrons inside the flow of current, which will only travel in one direction only (so to speak) The flasher cannister will draw whatever current it can get, to make and break and with the resistive load this happens twice as quick. You may find a flasher unit suitable to give a good result with it.
    One of the perils of LED turn signals I'm afraid.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    It says that's a heavy duty electronic flasher.
    I think you might need one that's not so heavy duty (meaning less draw)
    FYI - Bike guys use the Libertek variable rate electronic flashers.
    Or try the NAPA # 552 Variable load flasher
    http://www.bugmanweb.com/gsxr/flasher.html
  7. ULTM8Z
    8,890
    232
    May 19, 2000
    Los Angeles
    Sweet! Thanks Ace. There's a NAPA down the street from my house. I'll pick one up tomorrow.
  8. Camarofanatic73
    Camarofanatic73 Veteran Member
    2,373
    May 15, 2005
    Sacto,NorCal
    I've been using this for a few years now-
    Signal Stat 262
    IIRC, I bought them at NAPA
    FWIW,My marker & tailights (all 4 red tail) are LED bulbs and my turn sigs are still incandescents
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    :confused:
    If your turn signals are still incandescents......why the need for an electronic flasher ??
  10. Camarofanatic73
    2,373
    May 15, 2005
    Sacto,NorCal
    Because I bought everything at once and found out later that the LED bulbs did not fit into the front turn sig sockets, so I kept the old ones in place till I find a suitable replacement. Sheesh
