Gutting Doors question
Discussion in 'Competition Camaros' started by LeKid, Dec 9, 2011.
  1. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    When I get the under carriage done on my car, I'm definately doing this to mine!!!
    Great thread guys and keep up the good work!!!
  2. vegas1974z28
    4,623
    98
    Jan 10, 2002
    Las Vegas,NV
    ok I put wood behind the middle piece so I didn't drill thru the door, I thought the metal was a little thick and cramped to cut with the door ON
    cut the middle section so you can drill the holes, else the drill won't fit
    the dreaded hidden spot weld, you will have to remove the door spring
    the holes drilled on the "outside"
  3. Rich Schmidt
    Rich Schmidt Veteran Member
    4,247
    34
    Mar 27, 2010
    Denville NJ
    I wish I took picks of mine when I did them on my Firebird. I did it while I was reskinning the doors. I took out the crash beam,and replaced the door skin with a jap steel on. This also eleiminated the spray on sound deadener on the stock skin. The doors are like tin cans now,even with the glass and regualtors in them. If you are gonna swiss cheese the doors,concentrate on the foward end of the doors,thats the heaviest end,and a lot of the metal is doubled up on that end,so its like a BOGO deal. If you are concerned about loosing strength after cutting the holes,you can weld the sandwiched steel back together around the edges of the holes and get most of the strength back.
  4. strstk71
    strstk71 Veteran Member
    536
    Aug 12, 2005
    Surrey BC Canada
    Rich have you tried Lizard skin sound deadener its light weight spray that only adds a few ounces to the over all weight of the part. we have used it on the road car that i crew on and it works well .. you can also get it for heat sheilding as they have a spry on insulator as well.
  5. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Only had few minutes before dinner to make some holes. Took out another 1.5lbs. All I'm going to do for this year,(to the body), sure notice the difference in opening/closing the doors!
  6. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Just a note. Any one attempting this, the first thing you want to do is remove the door lock/cylinder. The bar will hit it and catch on it as you pull it out.
  7. JONESYFXR
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Would this be ok to do on my street/ strip car? I will be installing a 8pt in my car.
  8. OldCamaroNut
    OldCamaroNut Veteran Member Gold Member
    948
    Apr 27, 2005
    Rancocas Woods, NJ
    I'd leave the doors alone for a car you're going to be driving on the street. You need all the support the doors can handle in a crash.
  9. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,576
    Mar 29, 2012
    Mantweeka, California
    Hey put some holes on the outside too :) It will take some more weight off :)
  10. JONESYFXR
    2,177
    Oct 10, 2009
    BUFFALO, NY
    I'm trying to lighten up this thing. I have no clue what it'll weigh when I get it back together.
    I was even thinking of adding a bar along the inside rocker, IF I remove the door bars.
