Green Connector at rear of engine
Discussion in 'Engine Topic' started by MP81, Nov 5, 2017.
  1. MP81
    MP81 Veteran Member
    216
    Oct 10, 2016
    Washington Township, MI
    I've noticed this green connector that isn't connected to anything - and I can't say for sure if it has ever been hooked up.
    Any idea what this goes to?
  2. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    It is a diagnostic connector if I remember cotrectly. Doesn't plug into anything on the vehicle.
  3. MP81
    MP81 Veteran Member
    216
    Oct 10, 2016
    That would explain it then, thanks!
  4. RickM
    RickM Veteran Member
    366
    Apr 16, 2004
    Gaithersburg, MD
    It is used to set the mixture control solenoid duty cycle (dwell). If you are not using the computer anymore than you can remove the whole computer harness.
    If you are still using the computer just leave it unplugged. But you will need it to correctly dial in the carb.
    RickM
  5. MP81
    MP81 Veteran Member
    216
    Oct 10, 2016
    So do you just put a jumper in it to mess with the carb (similar to how you unplug the four-wire connector at the distributor to measure/set timing)?
    I still have the computer, so I will leave it right where it's at, unplugged.
  6. Joekool
    Joekool Veteran Member
    5,889
    27
    Feb 4, 2002
    Hollister CA USA
    My memory is fuzzy but I believe you connect a dwell meter to that connector and set the dwell of the mixture control solenoid when the engine is hot and in closed loop operation.
