got my Hotchkis springs and CPP C5 brake kit yesterday
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1971CamaroGuy, Mar 1, 2018.
  1. 1971CamaroGuy
    3,524
    98
    Oct 31, 2004
    Arkansas
    Still have some beefy sway bars and the rear disc kit coming in
    Now to find time in the next few weeks to drop in the motor and start putting the stuff on..def think I will need to either coat those spindles or paint them. They are cast right now with no coating.
    2018-02-28 18.53.02.jpg 2018-02-28 18.53.13.jpg 2018-02-28 18.53.16.jpg 2018-02-28 18.53.24.jpg 2018-02-28 18.54.53.jpg 2018-02-28 18.55.10-1.jpg 2018-02-28 18.55.31.jpg 2018-02-28 18.55.59.jpg 2018-02-28 18.56.03.jpg
  2. CamarosRus
    CamarosRus Veteran Member
    I wouldnt leave the the spindles bare steel....even with FLUID FILM your going
    to be fighting Rust !!!!!!!!!
    I Epoxy Primed (2K) mine with SPI (Southern Polyurethane) Black
    and then used aerosol "CAST BLAST" for that OE cast "LOOK"
    I'd do the same thing with Rotor Area that is not the brake pad contact surface
    Use CHEAP Aerosol Primer on Unclean cast parts you'll get poor
    adhesion and quick failure.
  3. 1971CamaroGuy
    3,524
    98
    Oct 31, 2004
    Arkansas
    Yeah I figured the fluid film might not be a good idea...thanks for the tips
  4. badazz81z28
    14,638
    159
    Las Vegas, NV
    I would use the caliper paint with ceramic. Dries quick and doesn’t flake with heat
  5. Shizzle
    Shizzle Veteran Member
    1,615
    205
    Aug 1, 2012
    oak lawn, illinois
    I had used Duplicolor wheel paint 10 yrs ago on the Brembos on my Charger, still holding up.
