going to give these a shot...
Discussion in 'Interior Restoration' started by ULTM8Z, Nov 25, 2018.
  1. ULTM8Z
    ULTM8Z Veteran Member
    8,914
    245
    May 19, 2000
    Los Angeles
    https://www.ebay.com/itm/372494365383
    they'll replace the generic LEDs I have now... maybe look a little more factory...
  2. dave@ztech
    2,128
    303
    Mar 27, 2016
    NY
    I like the idea, however, at 44mm or .472" seems a little large, right?
  3. ULTM8Z
    8,914
    245
    May 19, 2000
    Los Angeles
    should be ok I think. diameter is 12mm, which is. 472.
    44mm is the length.
    the current LED housings I have are .400 dia. so its only about a .035 per side increase in diameter and I have plenty of room for that.
    the next size down was 10mm which would have been too small I think
  4. ULTM8Z
    8,914
    245
    May 19, 2000
    Los Angeles
    Finally got these things installed. Came our really nice IMO...
    dave@ztech and Smokey15 like this.
  5. Knuckle Dragger
    Knuckle Dragger Administrator Staff Member Lifetime Gold Member
    14,039
    832
    Nov 2, 2002
    Waddell AZ
    Man you suck Mike. I had to buy some 8mm stuff for the truck. I don't need money anyway I guess :)
    Looks nice.
  6. Twisted_Metal
    26,346
    634
    All it needs is a shift lever on the column. ;)
    Seriously.... Very nice work! :cool:
  7. ULTM8Z
    8,914
    245
    May 19, 2000
    Los Angeles
    at some point I need to put in a non column shift steering column yeah... lol..
  8. Twisted_Metal
    26,346
    634
    You might be able to simply replace the collar where the lever attached.
    With your skills... You could probably fabricate one!
  9. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,295
    69
    Feb 2, 2008
    SF
    That looks really cool nice man
