GMPP LS Harness Owners
Discussion in 'High Tech Retrofits' started by badazz81z28, Feb 25, 2018.
  1. badazz81z28
    14,635
    159
    Las Vegas, NV
    Team,
    I cut my OBD II connector to shorten the wires and the picture I took pre-cutting doesn't match the color coding I'm seeing on time.
    On-line it show the Tan Wire is the GMLAN High and the Tan/Black is the GMLAN Low however on my OBDII based on the color shielding alone, it shows its pinned backwards....Can someone confirm maybe this is just a GMPP Harness thing?
  2. Goat
    1,797
    25
    Jun 7, 2001
    moncure, NC
    Here's mine - little fuzzy...Can't really tell from the pictures, but there are 2 tan wires, both entering the same hole and 2 tan/striped wires going in the same hole opposite of the tan ones.
  3. badazz81z28
    14,635
    159
    Las Vegas, NV
    Is the two solid tan wires installed in one slot over of the red wire? Pin 14
    The tan with stripe in hole 6
  4. Goat
    1,797
    25
    Jun 7, 2001
    moncure, NC
    I'll have to look more closely again tomorrow - not sure about pin #s...
  5. badazz81z28
    14,635
    159
    Las Vegas, NV
    Any updates by chance?
  6. Goat
    1,797
    25
    Jun 7, 2001
    moncure, NC
    Sorry, didn't make it out to the shop yesterday. I will for sure today though...
  7. bigkat_83
    bigkat_83 New Member
    29
    8
    Dec 7, 2014
    Bogart ga
    Mine is pinned just like the one in your pictures and works fine. Been using it with HP tuners and a OBII to Bluetooth converter.
  8. badazz81z28
    14,635
    159
    Las Vegas, NV
    so black striped tan wire pinned right next to the grounds? and the solid tan pinned one over from the red?
  9. Goat
    1,797
    25
    Jun 7, 2001
    moncure, NC
    Ok, don't see any numbers on the backside, but here is the wire arrangement:
  10. Goat
    1,797
    25
    Jun 7, 2001
    moncure, NC
    Did that help?
