GM 10 BOLT gear pattern
Discussion in 'Transmission & Driveline Topics' started by D94, Feb 6, 2018.
  1. D94
    D94 New Member
    27
    Feb 6, 2018
    Agreed. I will double check everything again. Pretty sure it's down all the way, when I change shims I can see some rub marks on them. I was thinking exactly what you said about not a lot of change. From other posts I've read and articles, most 10 Bolt 8.5 rebuilds guys are usually around .030-.035, .032 .033 average. Stock shim was .040 and that's what I started with. I thought I would have found the right spot by now. I will check it all again later after work. Thx again for all your input.
  2. D94
    D94 New Member
    27
    Feb 6, 2018
    IMG_2784.JPG IMG_2782.JPG Got some movement. This is with .020. Gonna try .022.
  3. big gear head
    big gear head Veteran Member
    6,076
    45
    Jul 30, 2001
    Central City, Ky.
    That's great. Yeah, try .021 or .022 and see how that looks.
  4. slayer021175666
    slayer021175666 Veteran Member
    1,217
    58
    Feb 29, 2016
    Idaho
    This is why I'm not crazy about trying it for my first time. Gonna have to, though. I wanna be a big gear head, too!
    big gear head likes this.
  5. D94
    D94 New Member
    27
    Feb 6, 2018
    IMG_2786.JPG IMG_2785.JPG Took a shot before going .022 made a jump to .025. I think I may be closing in?
  6. big gear head
    6,076
    45
    Jul 30, 2001
    Central City, Ky.
    To deep again. See the dark line at the root of the drive pattern?
  7. camaro71/holland
    1,097
    48
    Aug 27, 2003
    The Netherlands
    Almost there. You're closing in on the sweet spot! Then the fun can start with crushing the sleeve....
  8. D94
    D94 New Member
    27
    Feb 6, 2018
    Not trying to get ahead of myself, but in addition to the crush sleeve, I also got the ratech smart sleeve, and also a solid pinion spacer and shim setup. Any opinions on what I should go with when the time comes?
  9. camaro71/holland
    1,097
    48
    Aug 27, 2003
    The Netherlands
    If you already have both, go for solid. More work to set up, but once you're done you can just reuse it without pulling the pinion. You'll be thanking yourself if your seal starts to leak in the future. It also adds to the strength of you rear end a bit, by supporting the pinion bearings without the possibility to compress like a crush sleeve can (not everybody supports this theory although).
  10. D94
    D94 New Member
    27
    Feb 6, 2018
    IMG_2789.JPG IMG_2788.JPG Here's .022. Man.... I just don't know, maybe I'm there?
