General Suspension, Brakes & Wheel Stickies In Here
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by rscamaro73, Nov 14, 2007.
Thread Status:
Not open for further replies.
  1. rscamaro73
    rscamaro73 Administrator Staff Member
    As it states, we'll add to these as time goes on....
    impact on handling chart: http://www.nastyz28.com/forum/showpost.php?p=3234266&postcount=9
    wheel locks are useless:
    WHEEL AND TIRE COMBOS:
    http://www.nastyz28.com/forum/showthread.php?t=47101
    http://www.nastyz28.com/forum/showthread.php?t=147147&page=2&highlight=17x9
    Shock Absorber FAQ : http://www.nastyz28.com/forum/showthread.php?t=49990
    Steering Shaft Rebuild Process : http://www.nastyz28.com/forum/showthread.php?t=92926
    Herb Adams mod (relocating leaf spring front eye mount) : http://www.nastyz28.com/forum/showthread.php?t=64395
    Leaf Spring Upgrades : http://www.nastyz28.com/forum/showthread.php?t=57006
    Polyurethane Bushings : http://www.nastyz28.com/forum/showthread.php?t=70313
    The ULTIMATE C5 Brake Reference Post : http://www.nastyz28.com/forum/showthread.php?t=74546
    Changing subframe bushings http://www.nastyz28.com/forum/showthread.php?t=251412
    Subframe mount dimensions http://www.nastyz28.com/forum/showthread.php?t=231575
    HOW TO MEASURE STEERING BOX RATIO
    http://www.pozziracing.com/camaro_steering.htm#Steering box and ratio info
    Alston Racing/Pro-Touring F-Body Subframe Connectors:
    http://www.nastyz28.com/forum/showthread.php?t=79175
    http://www.nastyz28.com/forum/showthread.php?p=1210152
    How to make your own Art Rasmussen subframe connectors: http://www.nastyz28.com/forum/showthread.php?t=106859
    More DIY SFCs: http://www.nastyz28.com/forum/showthread.php?p=1910155&posted=1#post1910155
    Power Steering Hoses: http://www.nastyz28.com/forum/showthread.php?p=757543#post757543
    12" (1LE) Rotor Upgrade
    http://www.nastyz28.com/forum/showthread.php?t=109707
    http://www.nastyz28.com/2gcog/brake12.html
    http://www.nastyz28.com/forum/showthread.php?t=182800 (nice photo walk thru)
    RELATED PAD INFORMATION: http://www.nastyz28.com/forum/showthread.php?t=88955&highlight=d61+hawk
    S10-Blazer rear disc conversion
    http://www.nastyz28.com/forum/showthread.php?t=109454
    Suspension Terms for newbs:
    http://www.nastyz28.com/forum/showthread.php?t=113316
    Pedal Rod Ratio Chart
    General disc brake info for newbs
    Firewall Brace / G-brace Install:
    http://www.nastyz28.com/forum/showthread.php?t=86423
    Good info on C4/C5/C6 Brakes:
    http://www.nastyz28.com/forum/showthread.php?p=1345058#post1345058
    The best wheel/tire calculator ever
    Another calc:
    http://www.1010tires.com/TireSizeCalculator.asp
    How to rebuild OE calipers:
    http://www.nastyz28.com/forum/showthread.php?t=179858
    Great thread with pictures on changing subframe bushings
    How to rebuild OE rear drum brakes:
    http://www.nastyz28.com/forum/showthread.php?t=181713
    Rebuilding a MC
    http://www.nastyz28.com/forum/showthread.php?t=190597
    Vibration Issues: http://www.tirerack.com/images/tires/vibechart.pdf
    Early & later subframes are different!!!: http://www.nastyz28.com/forum/showthread.php?t=247098
    Early & later control arms are different!!:http://www.leverfamilysite.com/F_Body_Two_Types_of Lower.htm
    http://www.nastyz28.com/forum/showpost.php?p=3245292&postcount=2
    How to Replace a Steering Box - Video (UnseenZ28 aka "Klown's Garage")
    How To Replace Front Springs - Video (UnseenZ28 aka "Klown's Garage")
    How to Replace Rear Leaf Springs - Video (UnseenZ28 aka "Klown's Garage")
    All sorts of wheel tech Info: https://www.rsracing.com/tech-wheel.html
    • How to Measure Bolt Patterns
    • How to Measure Wheel Backspace or Offset
    • How to Determine Vehicle Fitment
    • Determine Wheel Caliper Clearance
    • Typical Lug Nut Torque Specifications
    • Wheel Terminology
    • Modular Wheel Inspection and Maintenance
    • Modular Wheel Leak Detection
    Advanced Suspension Discussion
    Springs and Natural Frequency
    Over-All Suspension Design and Theory
    The Big Suspension calculator spreadsheet (Download)
    Homemade hardline straightener: http://www.nastyz28.com/forum/showpost.php?p=2917662&postcount=242
    Convert toe degrees/inches
    https://robrobinette.com/ConvertToeInchesToDegrees.htm
    https://robrobinette.com/ConvertToeDegreesToInches.htm
    Camaro Component Weight Database
    http://www.nastyz28.com/forum/attachment.php?attachmentid=21108&d=1468428527
  2. BonzoHansen
  3. Lowend
    14,663
    337
    Mar 25, 1999
    San Jose, CA, USA
    added spreadsheet
  4. Lowend
    14,663
    337
    Mar 25, 1999
    San Jose, CA, USA
Thread Status:
