gauge cluster swap question
Discussion in 'Electrical Systems' started by Jimmac, Mar 6, 2018.
  1. Jimmac
    Jimmac Veteran Member
    242
    29
    Dec 24, 2013
    tucson az
    just picked up a cluster out of a 78 camaro full instrument cluster witb tach. I've got a 71 camaro with the idiot lights. I'd like to install the 150mph Speedo into the 78 cluster and get the factory gauges to work.
    So what do I need to make this work? new harness? It's got the printed circuit board, also has the block connector with a couple inches of wire still attached. jim
  2. Green hornet
    Green hornet Veteran Member
    1,307
    192
    Oct 11, 2015
    North Bay, CA
    Here is all the info you need to make the swap. I took my 150 speedo and installed it in the gauge clusters when I did the change over a few years ago. It was an easy project. Good luck.
    http://www.nastyz28.com/2gcog/tech/u14swap.html
  3. Jimmac
    242
    29
    Dec 24, 2013
    tucson az
    thanks for the link. it looks pretty simple. jim
