Garage Wall Finish - Galvanized Panels
Discussion in 'Garages, Workshops & Tools' started by NDZ, Oct 9, 2012.
  1. Termin8r
    Termin8r Veteran Member Lifetime Gold Member
    Dollars to donuts thats a real steel hood. And it's art, too!
    I like what you did, but couldn't do those walls because they'd get dented and then ruin the whole look or I'd have to replace the dented panel.
  2. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    I like it...........looks great
  3. Philip
    Philip Veteran Member Lifetime Gold Member
    1,806
    May 30, 2006
    Marana, AZ
    I have been struggling with what to do with the interior walls, that looks real good. Think it will work without the sheet rock behind it? Getting tired of seeing the pink in my shop.
  4. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    I threw up 3/4 wood sheeting. It cost a bit, but i can run the compressor and it is barely heard on the other side of the wall. On top of that, i can screw anything anywhere without it pulling out.
  5. Marks71BB
    You beat me to it...That hood is art!
    Love the clean look and if somethin catches fire...;) j/k
    I would use 1 X 4 sleepers at 2' horizontal to secure it to the studs otherwise 11/32" CDX plywood would work in place of sheetrock.
  6. BeefTip
    BeefTip Veteran Member
    722
    Aug 11, 2007
    Phenix City, AL
  7. 71flh
    71flh Veteran Member
    936
    20
    Jun 1, 2010
    DFW
    I'd put up, and 1st coat drywall before anything. After getting any wiring, or plumbing out of the way...
  8. NDZ
    NDZ New Member
    29
    Dec 23, 2009
    Fargo, ND
    Update - Flooring and LED lighting Finished
    Finally finished the floor this fall. I ground the entire 800 sqft on my hands and knees. A lot of work but necessary for good prep and adhesion. I used SW Macropoxy as a base then 100 lbs of colorflakes and covered it with Armorseal HS Urethane. Ended up ok but had some areas that we will have to touch up next summer. A couple of tricks, have 2 people or more help, thin the macropoxy to keep it wet longer so the flakes stick and then thin the urethane with mak to help it roll out better.
    Garage Floor Grinding
    Up Close
    Flakes Broadcast
    Finished Floor
  9. NDZ
    NDZ New Member
    29
    Dec 23, 2009
    Fargo, ND
    Led
    Installed LED strips from Amazon.com behind the cedar strips. Looks great a night and you can change colors for parties or flash the lights to the music!
  10. Marks71BB
    Nice hang-out. Love the lighting behind the hood!
