Garage Lift Recommendation
Discussion in 'Garages, Workshops & Tools' started by mgd1790, Jan 23, 2016.
  1. masck1
    masck1 Veteran Member Lifetime Gold Member
    140
    Mar 25, 2006
    Jacksonville Fl
    I'm looking real hard at a Atlas FM9SL lift , its flush with the floor
    FlaJunkie likes this.
  2. Mike N
    2,362
    310
    Jan 13, 2002
    Spencerport, NY.
    I've had one of these lifts for 9 years. I've only got a 10' ceiling and the columns on this clear by a few inches. I can put the Camaro and other short cars all the way up and a truck about 1/2 way up.
    http://www.alliedautoequip.com/product/allstar-al-9f-two-post-lift/
  3. Itsadryheat79
    Itsadryheat79 Veteran Member Lifetime Gold Member
    273
    Aug 4, 2009
    Chandler, Arizona
    Love my Direct Lift in my Tandum
  4. czizza
    czizza Veteran Member
    876
    23
    Jan 8, 2004
    N. Massapequa, NY, USA
    Okay ... I had my car on the lift and I decided to take pictures for you. I set the ruler at 9' 3" and then used the 3" from the case to give you 9' 6". Here is the car on the safety at 5' 8".
    As you can see you have about 3-5" to the ceiling.
    Now here is the car on the locks at 5' 8" ... the 8" inches above would allow you to go up to release the locks.
    At this point it is up to you but man do I love my Mohawk lift.
    I hope this helps.
  5. Itsadryheat79
    273
    Aug 4, 2009
    Chandler, Arizona
    FYI: My Tandum garage floor-ceiling height is 9' 4" high 8' 4" usable cuz opener is 12". Car on top is 4' 3" high
    Keep in mind this allows for travel above the lock so there is enough room for a car underneath. I have had a 79 corvette and a 79 and 69 z28 Camaro under it. The Direct lift allows easy adjustment for the height where the locks engauge.
  6. FlaJunkie
    6,067
    113
    Mar 24, 2001
    Rockledge, Florida
    You guys are great! I gotta study your posts!
  7. FlaJunkie
    6,067
    113
    Mar 24, 2001
    Rockledge, Florida
    By the way, do you feel you have adequate room to stand under your lifts and do work?
  8. czizza
    876
    23
    Jan 8, 2004
    My garage was built knowing I would have a lift in it so if you look at the picture I have about 5ft above the car I have 16ft ceilings and the shape is like the car, I have had my car up to the rafter and that is 7ft high.
    At the height I showed you would work for me because I am 5'8' but I believe you said you are 6'8" then you would work but at a disadvantage ... but you can pull your transmission and do exhaust work ... the best part you can do you brakes because you don't need to go more than 5'8" to be chest level.
  9. FlaJunkie
    6,067
    113
    Mar 24, 2001
    Rockledge, Florida
    I'm about 6 feet tall. I think just being able to lift it up 5 feet would be a big help.
