Garage Lift Recommendation
Discussion in 'Garages, Workshops & Tools' started by mgd1790, Jan 23, 2016.
  1. Glava
    Glava Veteran Member Lifetime Gold Member
    350
    Mar 23, 1999
    Central NY
    Direct Lift
    I have had my direct lift now for almost 2 years and it is great. It included the ramps, (4) drip pans and one HD movable pan for a bottle jack.
    At that time it was about $2,500.00 delivered and installed.
    My attached garage was high enough, but had to change the track and lift. I also went with a heater so I could work in the winter when the cars can't be driven -but it is nice to have the extra parking space too!
  2. fester
    fester Veteran Member
    132
    9
    Jun 26, 2016
    Central Texas
  3. CamarosRus
    CamarosRus Veteran Member
    I have a DIRECT Pro Park..Standard Length, Std Height.
    DIRECT made in China is owned by ROTARY Lifts, made in USA.
    DIRECT does offer Taller and/or Longer Lifts
    Greg Smith is a big dealer understood......His Private Label
    4 post lift looks like very much the same as the DIRECT
    Same factory...Same Lift ?????..............Hmmmm!
  4. FlaJunkie
    6,170
    147
    Mar 24, 2001
    Rockledge, Florida
    I'm going to have a 9 foot 6 inch high garage ceiling in the near future. Any of you with a lift have any comments? Is that too low to be useful with the Camaro?
  5. 70pete
    70pete Member
    95
    10
    Aug 19, 2014
    martinsville, nj
    I have a 9-6 ceiling and went with the atlas sissor lift. Works great
  6. BigBlock73
    1,964
    35
    Jul 10, 2002
    Accord,New York
    I have a 4 post lift and 11' ceiling height
    I just clear,the roof of the camaro,going to the top of lift height
    You'll need to stoop down a bit to walk under the car
  7. czizza
    czizza Veteran Member
    911
    27
    Jan 8, 2004
    N. Massapequa, NY, USA
    It depends on how tall are you ... and the type of lift. I have a 2 post so mine grabs from the Chassis, a 4 post grabs from the tire. If you have a 9' 6" ceiling and jacked up the car to the max (giving about an inch of ceiling clearance) you should be about the 5ft 8" mark under the car. So if you are like me 5' 8" you might have to do the mechanic spread to fit but if you are taller then you might be tighter.
  8. mgd1790
    mgd1790 Veteran Member
    919
    21
    Nov 25, 2003
    Suburban Chicago
  9. czizza
    911
    27
    Jan 8, 2004
    That's too tall ... A 2 post will give you more over a 4 post but at 6'4" you are SOL'ed.
  10. FlaJunkie
    6,170
    147
    Mar 24, 2001
    Rockledge, Florida
    I am guessing a two post would work the best for height, but does it have drip pan capability?
    I also would think a top crossbar two post is the strongest, and maybe I could modify the ceiling a bit to allow some more height.
    9 and a half feet is just not high enough to me. I will be on a chair or doing the mechanic spread underneath the car.
    I also originally wanted to use a four post to park another car underneath it. That may work, but I'm guessing I'll have limited height options.
