Garage bench suggestions
Discussion in 'The BS Topic' started by Joekool, Sep 28, 2017.
  1. Burd
    570
    97
    Oct 6, 2011
    image.jpg I just did 2.5 stalls of the garage floor, love it.
    joselk1 likes this.
  2. FreedomPenguin
    FreedomPenguin Veteran Member Lifetime Gold Member
    952
    18
    Sep 19, 2006
    Dayton, Ohio
    Is that racedeck? It looks nice. Glad you’re happy with it. Super easy to keep clean too.
  3. bmxmann
    bmxmann Veteran Member
    877
    Aug 11, 2004
    Fargo ND
    I just built mine with the wood i had laying around, 2x4's and plywood . Built a couple of them that way in my garage as needed. I have a pretty small garage and quite a bit of wood laying around though.
  4. chevyJeff1
    chevyJeff1 Veteran Member
    Always built my own too. Using bleacher type boards, (2x8) Find a corner in your space, use 2x4's along the drywall in the corner at your wanted height to set the back board on, use a 4x4 post in the outer corner for support, and seal the top with oil-based urethane.
  5. 70lt1z28
    1,972
    250
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I built my own at one time using scrap lumber. Worked out pretty well. I was very space constrained and wanted a solvent tank but didn't have the floor space. I found an old undermount SS sink for free and mounted it to the bench with a flip up cover. Use a metal 15 gallon tank and put a pump on a shelf about a foot off the bottom. Used that for years.
