fuel pump return line
Discussion in 'Troubleshooting & Diagnosis' started by white 81, Nov 29, 2002.
  1. white 81
    white 81 Veteran Member
    327
    Jun 17, 2002
    Sacramento, CA
    the holly pump im going to get doesnt have a return line, can my return line be safely blocked off? If so whats the best way to do this?
  2. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Put a rubber cap over it like you would use for a vacuum fitting on a carb, then install a small hose clamp if needed.
    Ran mine like that for a couple of years way back with no problems.
    70 SS 454 CI 650+HP All Aluminium Fuel Injected Small Block
  3. bpestilence
    bpestilence Veteran Member
    2,186
    Apr 5, 2002
    Bothell, WA, USA
    Or you could run a return-type fuel pressure regulator and maintain your emmissions legality.
