Fuel filler tube leak...
Discussion in 'Troubleshooting & Diagnosis' started by Ferg1031, Aug 22, 2017.
  1. Ferg1031
    Ferg1031 Member
    40
    May 2, 2016
    Portland, OR
    So, my 78' has a leak at the filler tube, thankfully it's only a problem after a fill-up. Looks to be leaking where the filler tube meets the tank. Is there a grommet or seal? On all the re-pop replacement tanks I've seen, its welded, but mine doesn't look to be...
  2. Green hornet
    Green hornet Veteran Member
    1,257
    183
    Oct 11, 2015
    North Bay, CA
    I had the same problem on my 70. Would stink up the garage with a full tank. No seal on mine where the tube met the tank. I just replaced the tank.
    Ferg1031 likes this.
  3. RS1979
    2,910
    367
    Jun 18, 2013
    Memphis, TN
    It's all one piece
  4. Ferg1031
    Ferg1031 Member
    40
    May 2, 2016
    Portland, OR
    Huh. Dangit. Guess mine broke at some point. Looks like new tank it is.
  5. Gary S
    21,077
    305
    Drain the tank and take it to a radiator shop. It was originally soldered at that point, and any good shop can resolder it for you if the tank is still in good shape.
  6. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,628
    80
    May 17, 2001
    Boston-ish
    Either replace the tank or have it fixed. My daily driver did the same thing a few days ago. I can't have fumes leaking out so I wire bushed it with a brass brush, brake cleaned it and slapped red rtv on the seeping area. No fumes no leaks for the moment. I'll be replacing the tank over the weekend.
