Front transmission pump
Discussion in 'Troubleshooting & Diagnosis' started by Chevyryder, Nov 2, 2017.
  1. Chevyryder
    Chevyryder New Member
    14
    Sep 27, 2017
    If my front transmission pump goes out can i replace it or is the whole trans bad it's a 2004r i drove it with a bad flexplat for 3 weeks and 2 days i was at a stop light felt a hard jurk and the car jurked every time I stopped I got home next day crunk it up to move so I can cut the grass nothing not nothing no jurk in any gear I checked trans fluid with car off it's full checked with car on same level as it is with car off
  2. budro6968
    budro6968 Veteran Member
    1,849
    250
    Apr 2, 2016
    Jax Florida
    Did you replace the flex-plate?
  3. Twisted_Metal
    25,611
    383
    If you did... Was the torque converter fully seated when you bolted the transmission to the block?
    Any crunching noise when you bolted them together is bad.
  4. Chevyryder
    14
    Sep 27, 2017
    Yes I replaced the flexplat haven't put trans back in yet cause I don't know if its any good since the front pump went out a guy told me the whole trans is bad
  5. budro6968
    1,849
    250
    Apr 2, 2016
    Jax Florida
    I would say it needs to be gone through. Not necessarily bad just might have particles of bushing and pump gears.
  6. Chevyryder
    14
    Sep 27, 2017
