Front tires 80 z28
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JD Z, Dec 3, 2017.
  1. JD Z
    JD Z Veteran Member
    I have 235/60 R15 on the front. I definitely feel/hear it bottoming out as I go through small dips. What was the factory front tire size for a 1980 Z28? I would like to have stock size on front. Thanks!
  2. Gary S
    Factory size for the 80 Z28 was 225/70-15 which are taller and narrower than what you currently have. The 225/70 had clearance problems from the factory and rubbed on most cars. The 235/60 you have is probably a better choice.
  3. JD Z
    JD Z Veteran Member
    There isn’t much room as the car sits. Narrower was my first thought. Stock being taller might still have problems. Thanks Gary for your insight. Much appreciated.
  4. CorkyE
    A lot of guys run 245/60-15 on all 4 corners. I had 235/70-15 for years but I had to do some clearincing in the front fender well. What is your spring/shock combo? If it's wore out, time to get into the catalogue.
  5. JD Z
    JD Z Veteran Member
    CorkyE. I’m guessing pretty stock on the spring/shock question. 77k miles and 37 years. Something might be due for replacement. Thanks.
