Front tire track width
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Mr_Z27, Jan 30, 2018.
  1. Mr_Z27
    Mr_Z27 Veteran Member
    2,599
    Dec 7, 1999
    Sioux Falls, SD
    So I currently have 2 inch dropped spindles with coil overs on the front and the coil overs are adjusted almost all the way to the top to keep an acceptable ride height without dragging anything. The tire sits just to the inside of the wheel well and rubs slightly on big dips.....my question is this: if I put my stock spindles back on and adjust the coil overs down to get back to the ride height I was at with the 2 inch spindles, will that position my wheels further out into the wheel well (away from engine)
  2. CorkyE
    9,840
    314
    Not my specialty but I would think the stock spindles, you putting the control arm travel back closer to the middle to get your desired ride height and there would be a sight outward difference.
