Freon capacity ((in pounds)
Discussion in 'Troubleshooting & Diagnosis' started by GPN, Aug 6, 2017.
  1. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    having R12 added to my 1979 Z. Can anyone tell me the capacity of the system?
  2. ol' grouch
    ol' grouch Veteran Member
    1,271
    228
    Jul 4, 2013
    Evansville, In.
    There should be a sticker on the components somewhere if you're using factory parts. I have capacity tables somewhere but it may take a while to find them. Are you sure you're getting R-12 and not converting to R-134? R-12 hasn't been available for years since Duponts patent expired and they got it outlawed. Unless you're getting some stuff that's been sitting, it isn't R-12.
  3. Bandit723
    Bandit723 Veteran Member
    2,260
    265
    Oct 1, 2016
    Waupaca WI
    Service manual say's 3 LBS 4 OZ.
  4. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Great Thank you
  5. Twisted_Metal
    25,460
    348
    The Harrison sticker on my evaporator case says: 3.25 lbs.
    A little difficult to get here but R12 is still made in Mexico.
  6. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Tnx, I'll check for sticker. Am fortunate to have some real R12.
    goid to know. Tnx
  7. Twisted_Metal
    25,460
    348
    Mine is an '80 Berlinetta but I'm pretty sure the system is the same as your '79 Z28 except for a couple of metric bolts for the compressor mount on my '80.
    Bandit confirmed the capacity from the manual.
    Good Job, Mike! :D
    If it was a 79 Z28, RS... I don't know anything about them.
  8. wnmech
    wnmech Veteran Member
    724
    36
    Jul 20, 2014
    grand prairie tx.
    I was buying R12 for my old corvette on craigslist for $10 a can. It's still out there and since most systems have been converted people are selling it cheap.
  9. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Agree
  10. harbone66
    3,446
    246
    Feb 15, 2011
    Central Illinois
    I have had a 30lb pig of R12 in my garage for almost 15 years. Probably havent used 6 pounds out of it in that time. I always think about selling it but you never know when an old system might need a recharge.
    If you are converting to R134a it will take less freon, if I remember correctly when I converted the 79 trans Am it took 2.4 pounds.
    GPN likes this.
