? for DSE sub frame users...
Discussion in 'High Tech Retrofits' started by Goat, Feb 15, 2018.
  1. Goat
    1,813
    28
    Jun 7, 2001
    moncure, NC
    I'm too tired and lazy to pull the plastic caps off to look. Need to order some fittings for the power steering. What fitting mates to the DSE R&P hydraulics? I want to go from there to a 6-AN...
    Thanks.
  2. Goat
    1,813
    28
    Jun 7, 2001
    moncure, NC
    Thanks. Do you know which size we need, or is the 5/8 for one side and the 9/16 for the other.
    Also, the Vintage pump puts out 3-3 1/2 gpm. So I guess I'm needing the flow control valve that knocks it down to 2 gpm also?
  3. 71RS/SS396
    71RS/SS396 Veteran Member
    2,607
    22
    Aug 26, 2008
    Wake Forest NC
    You need one of each fitting and yes you need the flow control valve. The hardline tube kit for the pump they sell makes life easier too for plumbing. http://www.detroitspeed.com/Steering/091701-hardline-pressure-tube.html
  4. Goat
    1,813
    28
    Jun 7, 2001
    moncure, NC
    Thanks. I already got the hardline, and yep it looks worth the money. Where in the plumbing does the flow valve attach, the pump side or the other end? And do I need any additional adapters to install it?
    Nevermind, I figured it out.
  5. badazz81z28
    14,959
    191
    Las Vegas, NV
    The flow valve on my stock ps pump is on the pump outlet.
