Floor Pan Heat Shield
Discussion in 'Interior Restoration' started by badazz81z28, Oct 1, 2017.
  1. badazz81z28
    14,954
    191
    Las Vegas, NV
    My floor boards in the driver and passenger side get very hot because that's there the header and exhaust flanges are. I have the "peel/seal" on the outside, but the aluminized is facing away from the heat thus I don't see it reflecting heat out. Is there a material that I can put on the outside of the floor board to reflect the heat out? I see a lot of the new cars have this, but I can only find $$$$ DEI
  2. G72Zed
    G72Zed Veteran Member
    597
    74
    Sep 8, 2015
    I have had very good results with the Cool It Thermo Tec aluminized heat barrier. A roll of 24x36 inches is part number 13585, no sure on price, but works well
  3. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Ironic that the shiny side is up and they still call it heat and sound barrier. Is your peel and seal letting heat through? What brand did you use just curious cause I’m running the “cool it from thermo tec” and very curious myself.
  4. Scott51
    Scott51 Veteran Member
    535
    39
    Jan 2, 2012
    New Zealand
    Turbo70Camaro likes this.
  5. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Thats the stuff I use on the firewall in the engine bay, good product...
  6. BonzoHansen
  7. FS87LT
    FS87LT New Member
    10
    Apr 3, 2010
    DFW, TX
    Worse case, wrap the exhaust items under the floorpan in ThermoTec header wrap.
    FS87LT
  8. Rickyb1968
    Rickyb1968 Veteran Member
    330
    17
    Feb 14, 2018
    When you click on the link for the heat shield it states that this product is not for use under carpet. I thought that was the idea to add it to your floor pans. Rick
