Flange pliers help!!!
Discussion in 'Garages, Workshops & Tools' started by rusty76, Aug 5, 2009.
  1. rusty76
    rusty76 Veteran Member
    267
    Apr 24, 2009
    Clarksville Tn
    I am trying to find a pair of flange pliers. I have a guy coming to weld the patch panels on my 76 this weekend and I cant find a pair of flange pliers. I dont have time to order them onlline. Is it possible to make a pair out of vise grips? Or is there any other tool I could use to make a flange. Thanks
  2. Twisted_Metal
    25,815
    468
    Northern Tool carries an air powered one.
    There's a Northern Tool in Madison, TN
    Give them a call, they may sell a hand operated one too. 615-865-8920
  3. rusty76
    267
    Apr 24, 2009
    Clarksville Tn
    I just called them, They only carry the air powered. It looks like it might be pretty simple to get a couple pieces of steel and weld them to a pair of vice grips. What do you think?
  4. BondoSpecial
    8,695
    Sep 20, 2004
    Southern Maryland
    The manual flanger pliers, ARE vice grips w/ welded on die. literally. I bought a set locally and it still says vice grips on them. If your local paint and body supply store does not stock manual flanging pliers, it's not a very good paint and body store. I'd call around and see if someone has them.
  5. Cardinal
    8,243
    13
    Jun 22, 2003
    Endicott, NY
  6. rusty76
    267
    Apr 24, 2009
    Clarksville Tn
    I have literally called every store in town, I even called a few body shops to see if they could help, still comin up empty handed. I think making them may be the only choice at this point.
  7. rusty76
    267
    Apr 24, 2009
    Clarksville Tn
    How wide should the 1/8" flatstock be ?
  8. krabben1
    8,053
    May 16, 2007
    ( . Y . )Delco
    Harbor Freight has many things good for one shot deals.These are there.
  9. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    Check HVAC stores, not your home depot (although they might have them) but stores that caters to the HVAC companies in your area. They should have them since we use them to make ducts with.
  10. 79camaro2001
    4,757
    May 4, 2003
    Monroeville, PA
    When I read this I think of the seamer hand tool, or do you want the clamp action also?
    If you want the seamer then check the HVAC store and i also just saw on Home Depot that they carry it.
    If you want the vise grip go to a welder supply store.
