Exhaust manifolds
Discussion in '1970 - 1973 Specific' started by ncarcamguy, Feb 3, 2017.
  1. ncarcamguy
    ncarcamguy New Member
    26
    Jan 27, 2017
    Hi again Nasty world!!! Im working on a 1970 camaro and looking for some exhaust maifolds that flow. Did Chevy make a manifold that flowed more than others. I would like to stay " stock" looking if possible. The ram horns wont fit. Any ideas? Thanks
  2. tom3
    tom3 Veteran Member
    11,155
    156
    Aug 1, 1999
    ohio
    Often wondered about that myself. Used to think those log type manifolds were probably a real good deal by the looks. Then got some actual info about how bad they really are. I'm no big fan of headers, but a fan of performance, so I guess we're stuck with them. Would like to find some shortie type header that uses the stock pipes, don't know of any.
  3. CamarosRus
    CamarosRus Veteran Member
    tom3, " shortie type header that uses the stock pipes"
    Could you explain WHAT this means
    Header = Aftermarket non Chevrolet HEADER
    Stock Pipes = Stock Exhaust Pipe, Stock Head Pipe (where it connects to stock manifold)
    twozs likes this.
  4. twozs
    twozs Veteran Member
    8,772
    156
    Aug 5, 1999
    hopewell jct ny
    Shorty headers are short pipes with no collector tube on the . HP gain is minimal compared to " long tube " headers .
  5. ncarcamguy
    26
    Jan 27, 2017
    I was thinking more along the lines of after market, cast iron,larger I.D. , but looking stock. I was told that circle track guys in some classes must use iron exhaust manifolds. Guess I ll keep looking.
  6. shad_van
    shad_van Veteran Member
    200
    Jun 15, 2012
    las vegas, NV
    supposedly, the Corvette exhaust manifolds were the better flowing ones. but they are the center dump ram horn style on a small block, so I doubt they will fit. for Big Blocks it was also the corvette header style exhaust manifold, but again they probably wont fit. I would look for a set of Factory 70-71 LT1 350 Camaro manifolds. as it was the highest powered original motor in second gen. followed by the 73-74 L82 manifolds. but neither will give you the performance of a good long tube header. I like the ceramic coted ones. I also use copper gaskets to prevent leaks. they seem to last longer then the crappy paper gaskets. also if you can compare brands, look for at the header flange where it bolts to the heads. the thicker the better, it prevents warping and helps the gaskets live longer. some of the more expensive headers are ground flat to make a better seal as well.
  7. djkaplan
    djkaplan Veteran Member
    160
    Mar 27, 2016
    Victoria, bc
    Might not work but it might be possible to port you stock manifolds.
  8. Dave Nelson
    3,677
    1,000
    Dec 19, 2003
    Vineland N.J USA
    Check out Extrude Hone AFM.
  9. 70lt1z28
    2,339
    341
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Extrude hone helps, but just a little and if you go too far the manifolds will crack. Not much can be done here, within reason. Seems strange that by now with all of the 2nd gens and others (Chevelles, Novas, etc) out there that someone hasn't cast up a high flow iron manifold. I guess it is just too easy to go to headers.
  10. ncarcamguy
    26
    Jan 27, 2017
    Extrude hone.....WOW what a process. Thanks again. Still looking
