Engine is stalling
Discussion in 'Troubleshooting & Diagnosis' started by zekefreak, Aug 16, 2017.
  1. Joekool
    Joekool Veteran Member
    5,889
    27
    Feb 4, 2002
    Hollister CA USA
    I'd run the car in your driveway until its good and warm, then check the primary resistance of the ignition coil, it should be .2-1.0 ohms, any variance from that spec and throw it out and buy a new one.
  2. Plater Tom
    Plater Tom Veteran Member
    1,325
    13
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    I think that is sound advice.
  3. zekefreak
    zekefreak Veteran Member Lifetime Gold Member
    1,533
    Apr 16, 2006
    western PA
    I don't think that will work. I can drive it around town all day with no problems. It's during high speed- long distance that it cuts out on me.
  4. Coadster32
    1,417
    73
    Oct 2, 2013
    Milford,CT
    Perhaps not, but it couldn't hurt either.
  5. zekefreak
    1,533
    Apr 16, 2006
    western PA
    I was told by my inspection mechanic, who is also a very successful drag racer, that the coil is going bad. Makes sense to me so I ordered a new coil and will be replacing the old one soon. I will keep you updated on the results. Stay tuned..............
  6. zekefreak
    1,533
    Apr 16, 2006
    western PA
    I replaced the coil in the distributor cap and today I took it for a spin on the turnpike going 70 mph for about an hour. Then, later in the afternoon I did a return trip home and had NO issues or misses at all, either way! So I believe the problem is solved. (Keeping fingers crossed) Thanks for all your responses and help.
