Engine decoding
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by Carqle, Nov 19, 2017.
  1. Carqle
    Carqle New Member
    Nov 19, 2017
    Hello could use help decoding this motor..casting #1400207, passenger front block pad V1221THW..CFF136452
  2. Gary S
    21,442
    412
    I can't find a THW listing, but that is a truck code. The T- - codes are pickups, vans, and larger trucks.
  3. Carqle
    Carqle New Member
    Nov 19, 2017
    Thanks, I'm running into the same issue , at least knowing it's a truck motor helps narrow my search.
  4. 74BIBELOT
    74BIBELOT Veteran Member
    Complete number is 14010207?
    If yes, it’s an 80-85 truck 2 or 4 bolt 350.
  5. Carqle
    Carqle New Member
    Nov 19, 2017
    thanks, I've now looked three times, I'm seeing 1400207. I'll look again tomorrow. The vin # on the fron which I originally read as cff136452, I rechecked it today and could see a very faint 1 in front of the c. I'll recheck
  6. Carqle
    Carqle New Member
    Nov 19, 2017
    New question , I have another motor I'm trying to id. Engine stamp ends in EE, code shows 1968 with comments of AX....does anyone know what AX designates?
  7. jbloake
    jbloake Veteran Member
    280
    44
    May 1, 2002
    Atlantic Canada
    I found EE for 1968 is a 327 with a powerglide trans . The (A ) would stand for A body like Chevelle . The (X) would be X body like Nova .
