Drop Spindles?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by MEAN79, Oct 23, 2009.
  1. huggermaro
    huggermaro New Member
    18
    Mar 21, 2011
    Surrey
    I have a 81 Z28 with all new stock front suspension and was wondering if anyone has had any success with 2" drop spindles and fitting a 17" rim with a low profile tire? please help me?
  2. hillbilly75
    hillbilly75 Veteran Member
    415
    Jan 7, 2011
    Nowheresville
    My .02 is to go with springs over spindles to lower your car. I know in your post it says all new stock suspension but mine at one time was like yours and even with just adding a nice spring like Hotchkis it really made the car more fun to drive.
  3. mgs1971
    mgs1971 Veteran Member
    226
    Jan 11, 2009
    CLEMSON, SC.
    According to most of this post, I guess my set up will be a total failure. Here is what I have already bought.
    McCaughly 2" drop spindles cut to fit corvette brakes. QA1 coil overs and PTS large diameter swaybars front and rear and an IROC steering box.
    I plan to use my stock powder coated upper and lower control arms to start and then upgrade to Heidt tubular upper and lower LCA's at a later time.
    I have an LS1 and a 6 speed from a 2002 Z-28 that was totaled (rear ended) with only 2000 miles on it.
    I will be running 18"s on the front.
    Why is this not going to work?
    I appologize for addiding to this thread instead of starting a new one but the info should be relevant to the original subject.
    Thanks,
    Mike
  4. stapleszoo
    stapleszoo Veteran Member
    108
    May 1, 2011
    Glastonbury, CT
  5. stapleszoo
    108
    May 1, 2011
    Glastonbury, CT
    I know this an old post- I also have 2" drop spindles (not sure of the brand) and I have a set of 17 x 8 rim and planning to run a stagger tire set up with 235/50 17 fronts and 245/50 17 rears. Has anyone had any issue with this type of setup?
