drivers door mirror disassembly
Discussion in 'Tips 'n' Tricks Topic' started by pbradshaw, Jun 21, 2014.
  1. pbradshaw
    pbradshaw New Member
    23
    Aug 1, 2013
    philadelphia, pa
    anyone have any thoughts on the best way to remove the flex cable from either the mirror or the inside control without damaging anything? Thanks
  2. 2nd gen Guy
    2nd gen Guy Veteran Member
    612
    Jul 29, 2012
    Coon Rapids, Mn
    I think its a one pc unit and can't be removed from either end. I say this b cuz I had a broken finger on a cable at the mirror and spent some time trying to figure out how to fix it to no avail. I also have looked around for just a cable and I haven't found one
  3. 351maverick
    351maverick Veteran Member
    3,348
    254
    Aug 11, 2010
    erie, PA
    there is no easy way to take the assembly apart without destroying it
  4. CDesperado
    3,287
    Oct 1, 2004
    Dallas Texas
    The problem is the pot metal used to attach the knob on the remote. It crumbles pretty easily if you jack with it too much, and the assembly on the mirror isn't removable easily either.
  5. pbradshaw
    23
    Aug 1, 2013
    philadelphia, pa
    Thanks Guys for your response, I nguess i will remove and replace with a repop from Ecklers.
  6. garyandcindy
    garyandcindy Veteran Member
    1,600
    Oct 20, 2004
    cumming,ga-usa
    You can use a dremel tool and carefully enlarge the hole in the base of the mirror until it's big enough to pull the control end thru.That's what I did.Once you put the mirror back together you will never know it.
  7. pbradshaw
    23
    Aug 1, 2013
    philadelphia, pa
    Thank you, i was able to get this out without causing any damage, i should be able to use it over.
