drive shaft
Discussion in '1978 - 1981 Specific' started by railxmad2, Feb 18, 2018.
  1. railxmad2
    railxmad2 New Member
    17
    Feb 11, 2018
    going on a parts search i have questions
    drive shaft for a 1979 camaro Z28 5.7 350 4 speed
  2. Glava
    Glava Veteran Member Lifetime Gold Member
    339
    Mar 23, 1999
    Central NY
    Z28 4 speed driveshaft stripes2.JPG Z28 4 speed driveshaft stripes.JPG I looked in my assembly manual and it lists two drive shafts:
    7819344 Prop shft assembly M15(3 speed manual) /M20 (4 speed Manual)/M38 (3 speed automatic)
    7819345 M21 ( Which is the 4 speed close ratio BW T10 in the Z/28)
    So it looks like you need the shaft specifically for the Z/28 -I am not sure what the difference is?
    Here are a couple of shots of mine with the paint stripes on them that may help you ID one when you're looking.
    BTW, that is a sharp looking 79Z!!
  3. BonzoHansen
    Output shaft sizing. IIRC a th400 uses the same yoke as a t10
  4. railxmad2
    17
    Feb 11, 2018
    over all i was worried about lenght changing yokes is easy but if i got to buy one i wanted to make sure i am looking for the right shaft don't want to buy what i cant use.
  5. Glava
    339
    Mar 23, 1999
    Central NY
    Just a question for my education -the 79 z had a TH 350 right?
    So, he can get any shaft, but may have to change the yoke.
  6. Twisted_Metal
    25,990
    507
    2nd gen Camaros used a driveshaft 48.5" from center of U-joint to center of U-joint for a short tail TH350 or 200-4R.
  7. Zspoiler
    Zspoiler Veteran Member
    2,683
    158
    May 6, 2012
    Federal Way, Washington
    I have used my stock driveshaft when I did my conversion at first to a Muncie M-21 4 speed on my 1979 Z-28 RS Camaro..And by using a Super T-10 /Turbo 400 yoke right from the Chevrolet dealer at the time. The Z-28 has a bigger drishaft than a regular "BowTie car.
  8. BonzoHansen
    Changing the yoke you should rebalance the driveshaft
