Door trim kit
Discussion in 'Ground Up' started by andrew carter, May 24, 2014.
  1. andrew carter
    andrew carter Member
    39
    Sep 8, 2013
    mastic new york
    Got the trim kit from ground up with the inner and outer felt for the windows .
    But they are to short for the doors.has anyone else had this problem
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,117
    Feb 16, 2012
    California
    Funny...I got PUI felts that are too long!
  3. andrew carter
    39
    Sep 8, 2013
    mastic new york
    I would rather have to long then to short at least that way I can always cut to fit . the kit I got is 6 inch's shorter then the door
  4. 2nd gen Guy
    2nd gen Guy Veteran Member
    612
    Jul 29, 2012
    Coon Rapids, Mn
    What yr is your car ? I've been looking at various yrs before buying mine because theres umpteen different styles due to trim pkgs and found that they only go just past the mirror, not all the way to the end.
    I have a set that came with the car extra and thot they were too short till I started looking around
  5. andrew carter
    39
    Sep 8, 2013
    mastic new york
    its a 76[​IMG]
