Door hinge pins and bushing replacement questions
Discussion in 'Body Restoration' started by Mr Sunshine, Dec 23, 2017.
  1. Mr Sunshine
    Mr Sunshine Member
    61
    Dec 12, 2016
    Missouri
    Just taking everything apart to replace hinge pins and bushings in my 78. When I removed the spring the "roller" bearing or detent bearing (not sure proper name) just fell out. Is this normal or is there another bushing required for it?
    And the spring I got from Speedway is shorter than the one I took out. It's also marked 68-74 on the bag. Anyone know if this is the correct replacement?
  2. CamarosRus
    CamarosRus Veteran Member
    20170608_161125.jpg 20170608_161142.jpg 20170612_144634.jpg Find the thread where I have pics of replacing detent roller with 3rd gen roller and pin......
  3. Twisted_Metal
    25,377
    327
    The spring doesn't look like it will work... I doubt the hinge tab will fit inside of it properly. (And too short)
    Send it back.
  4. Mr Sunshine
    Mr Sunshine Member
    61
    Dec 12, 2016
    Missouri
    Thanks CamaroRus,
    My original roller bearing has the radius groove instead of flat. Does the flat roller bearing still work well with the factory detent arm?
  5. Mr Sunshine
    Mr Sunshine Member
    61
    Dec 12, 2016
    Missouri
    Thanks Twisted_Metal,
    I will be sending the springs back. I went and checked the part number on Speedway's web site again and they state it's good for a 78, but obviously it's not. Do you think it's necessary to replace the spring? Mine doesn't seem too bad.
  6. Twisted_Metal
    25,377
    327
    Those springs are quite tough.
    I don’t think I’ve ever seen one break so it should be fine to reuse.
    I spring compressor made for the job simplifies reinstallation.
    Mr Sunshine likes this.
  7. Mr Sunshine
    Mr Sunshine Member
    61
    Dec 12, 2016
    Missouri
    Yes I do have the spring compressor, worked great getting springs out.
    I think I'll reuse my original springs.
    Thanks again and Merry Christmas!
