Door glass Question?
Discussion in 'Tips 'n' Tricks Topic' started by smallblockchev, Jan 3, 2018.
  1. dave@ztech
    1,561
    197
    Mar 27, 2016
    NY
    I would get a really bright light and have some one help , closing the door, while you get into the floor board, and as they close the door see if you can see what is vibrating , and anything with play, is going to help with making things rattle
  2. smallblockchev
    smallblockchev Veteran Member
    322
    Dec 23, 2011
    st michael, mn
    Does anybody know how much play should be in that bushing in the channel it rides in ???
  3. dave@ztech
    1,561
    197
    Mar 27, 2016
    NY
    That bushing is in a greased channel , is it not? and shouldn't really rattle, I would think, its the items attached to the regulator , you need to look through the door , or maybe use a bent coat hanger, to reach around and shake the components to find the culprit, just my .02
  4. smallblockchev
    322
    Dec 23, 2011
    st michael, mn
    Its the bottom of the glass thats making the noise, i can grab the glass on the bottom and move it back and forth because there is about a 1/4 inch or more of play in that bushing.
  5. dave@ztech
    1,561
    197
    Mar 27, 2016
    NY
    Ok, however I think there is supposed to be so movement, however, can you move it and get the rattle? That's why I think you need a person to close the door while you watch
  6. smallblockchev
    322
    Dec 23, 2011
    st michael, mn
    Yes, when i shut the door i can see the glass wooble at the bottom near that bushing
  7. smallblockchev
    322
    Dec 23, 2011
    st michael, mn
    I'm thinking i need to replace the bushing.
    Does anyone know where to get a replacement? not sure what its called,
    Rear window guide maybe?
  8. dave@ztech
    1,561
    197
    Mar 27, 2016
    NY
    Well, then you are probably correct and that piece needs to be replaced, NPD, sells various parts for the window mech, you may be able to just purchase that and replace and see if that solves the problem, however, if all of the parts are old, maybe best just to replace all of them while you are there, they are not that expensive.
  9. smallblockchev
    322
    Dec 23, 2011
    st michael, mn
    Just looked it up at Classic Industries, rear window guide roller.
  10. smallblockchev
    322
    Dec 23, 2011
    st michael, mn
    I think i'll start with that and go from there.
    Thanks for the help, i'll let you know if that works.
