doesn't fit-sail panel int564 Camaro Central
Discussion in '1970 - 1973 Specific' started by Chuck71RS, Apr 18, 2017.
  1. Chuck71RS
    1,013
    24
    Nov 24, 2012
    Houston, Texas
    Bow headliner: For a sail panel to fit, the curved area at the top that goes around the trim between the headliner and windshield is on the left side of the screw hole
    Below is the Int564 with the curved area to the right of the screw hole
  2. wasp
    wasp Member
    76
    Mar 8, 2009
    Milpitas, CA
    Good info, Thank you
  3. 70 Proof
    70 Proof Veteran Member
    324
    19
    Sep 28, 2014
    Southern Utah
    Chuck
    I had the identical problem a couple of years ago with sail panels I bought from Classic Ind. Like Camaro Central and other suppliers, CI claimed at the time that their sail panels fit all 1970 - 74 Camaros, when In fact they didn't. Since then CI may have rectified the problem as they are now advertising sail panels specifically for 70 - 73 Camaros. I plan on giving them a try in the near future. However as you found, there are still suppliers claiming that 'one size fits all' when it comes to their sail panels? Whats up with that? Did some 70-73 Camaros have something other that bow headliners?
  4. haroldpo6
    haroldpo6 Veteran Member
    294
    May 9, 2015
    PC Fl
    I just installed some from John's classic parts this past weekend and the curved area was wrong(had to trim) and the hole was wrong also. Mine is a 70. Said it fit 70-73
