DIY trick fender braces
Discussion in 'Tips 'n' Tricks Topic' started by RC79camaro, Jul 8, 2011.
  1. Buickfunnycar
    Buickfunnycar Veteran Member Lifetime Gold Member
    I think those defeat the purpose of what the original cheap-o stock pieces were designed to do...but if you're happy,I'm good.:cool:
  2. 5spd540
    12,344
    12
    Sep 19, 2009
    Guyton, GA
    I think it is just that they are different
  3. tferg51
    tferg51 Veteran Member
    181
    May 10, 2011
    New Waverly, Texas
    What would the stock braces do that these won't?
  4. Buickfunnycar
    Not flex and be rigid...sorta what you look for in a fender brace...to tie the fender to the rad support.
  5. John Wright
    14,177
    90
    Aug 9, 2002
    Rustburg, Va
    ^^^ what do ya think, am I close or all wet?
  6. BondoSpecial
    8,695
    Sep 20, 2004
    Southern Maryland
    Look at the heim ends. Heim ends allow rotation which means these braces will have zero torsional stiffness when installed.
  7. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    Work
  8. 5spd540
    12,344
    12
    Sep 19, 2009
    Guyton, GA
    So do you guys think they wont work as well as a stock set?????????????????
  9. dcozzi
    dcozzi Veteran Member
    2,247
    55
    May 1, 2002
    Phoenix, AZ
    No.
    There is room for movement since there are heims on the end.
    They look cool and hold the core support to the fender like a champ though.
  10. Buickfunnycar
    Tell us what you really think Laine...:crazy:
