Distributor?
Discussion in 'Troubleshooting & Diagnosis' started by Millz90, Feb 2, 2012.
  1. Millz90
    Millz90 Veteran Member
  2. kstripes
    kstripes Veteran Member Lifetime Gold Member
    512
    Mar 4, 2005
    Margate,FL,USA
    Just in case, check the hoses. The inlet hose from the metal line to the pump could be cracked and suck air. Also check the oil to make sure no gas went into the crankcase from a torn fuel pump diaphragm.
  3. Millz90
    ok...would gas in the oil make the car not start? Im having a problem where the car will start and run for a while then when i turn it off and try to start it again it just whines like its started or like im hold the key to long but then it doesn’t start?
    Could it be bad spark plugs?
  4. COPO
    16,331
    260
    Check the plugs, maybe their soaked with gas from being flooded. A wet plug won't fire.
