Distributor?
Discussion in 'Troubleshooting & Diagnosis' started by Millz90, Feb 2, 2012.
  1. Millz90
    Millz90 Veteran Member
    So i started my 79 Z last night and it was idling pretty good but i figured i would loosen the distributor and tune it a little. Well i was getting it a little better when the car stalled.....so i got back in the car to start it again and now its just turns over.....turns over...turns over...will NOT start?
    Could i have twisted the distributor so much that it wont start now?
    I didn’t check to see if i had spark but like i said it was running pretty good before i stalled and now wont start?
  2. COPO
    16,332
    261
    Try putting it back to where it was when it was running. You do have a timing light, right? If not, don't try and time it without a light.
  3. Millz90
    I did try to put it back where it was and still would not start just kept turning over....
    Timing light...that is the other question i had. I DO have a timiing light BUT there is not timing strip on the engine any more....Can i put a new one on?
  4. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,361
    Apr 23, 2010
    St.Augustine,Florida
    You can get a new timing tab. I think any one for a sbc will work on a sbc. They all basically have the marks in the same place. Just bolt it to your timing cover.
  5. High Country Z
    High Country Z Veteran Member
    Spark plugs are probably fouled out now.
  6. Millz90
    Will they be black if they are bad?
  7. Millz90
    So there should be a place to bolt a new one on hu? Shoudl there be mark on the flywheel as well?
  8. High Country Z
    Black, sooty, wet, change them if they are.
  9. Millz90
    ok thanks.....i dont think i could have tunred the ddistributor so much that it wouldnt start....i was barley turning it to beging with.
    I guess it could of been flooded or like you are saying the spark plugs fouled up.....would they foul up that quick? Like minutes?
  10. High Country Z
    When you crank the engine like that and it doesn't fire the plugs can get soaked with fuel. Pull one and see how it looks.
