Differential code help
Discussion in 'Transmission & Driveline Topics' started by Green hornet, Nov 25, 2017.
  1. Green hornet
    Green hornet Veteran Member
    1,074
    142
    Oct 11, 2015
    North Bay, CA
    My Camaro is a 70 but I know it doesn’t have the original diff in it because it a 10 bolt posi with 3.73 gears. The decoding numbers don’t make any sense. On the front of the passenger axel housing is stamped PS G62742. That doesn’t match any info in the decoding section. Is it possible the diff is out of a nova? Anyone have any ideas what this diff is. I have included some photos.
  2. Gary S
    20,861
    237
    PS is the code for a 2.41 posi used by GM on Camaro and Firebird from 1975-1981.
    Green hornet likes this.
  3. big gear head
    big gear head Veteran Member
    5,917
    23
    Jul 30, 2001
    Central City, Ky.
    The '70 rear end would have been a 8.2 10 bolt. That is the 8.5 10 bolt. With the posi and 2.41 gear I'd say it was from a Trans Am.
  4. Green hornet
    1,074
    142
    Oct 11, 2015
    North Bay, CA
    Thanks for the help guys. I did the tire to drive shaft turns, it's got 3.73 gears. Someone at some time replaced the diff housing and put different gears in it.
    Gear head, would the bearing kit be the same for the two housings. I have a noise in the rear and it seem to be getting louder. Going to replace the bearings, not sure of the condition of them. Going to inspect the clutches while I'm there.
  5. big gear head
    5,917
    23
    Jul 30, 2001
    Central City, Ky.
    You need a kit for the 8.5 rear end. The 8.2 uses some different parts.
