Did my Camaro have a TCS system
Discussion in 'Original Drivetrain Topic' started by lapedr, Oct 24, 2017.
  1. lapedr
    lapedr Veteran Member Gold Member
    524
    Jan 28, 2003
    Pembroke, GA
    I am confused about the TCS switch and if my Camaro had one originally or not. My Camaro originally was a 72 Sport Coupe, with warning lights, P/S, manual disc brakes, floor console, non-AC, L65 350 engine, and TH350 trans. The reason I ask is because I am rebuilding the engine and am ready to install the temp sender switches. My assembly manual shows that the drivers side uses a 2-prong temp sender, and on the pass side it uses a single prong temp sender. I guess I want to know if that is the correct setup for warning lights and no AC.
  2. twozs
    twozs Veteran Member
    8,782
    160
    Aug 5, 1999
    hopewell jct ny
    i should . is there a plug on the transmission ?
  3. lapedr
    524
    Jan 28, 2003
    Pembroke, GA
    No there is no plug on the trans, did they only have TCS with TH400 I wonder
  4. 70lt1z28
    2,475
    365
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I wouldn't think it would have much to do with the choice of transmission. When spec'd for a particular car, it was on whether it was a 4 speed or auto. Since it was an emissions thing. Did your car have an A.I.R. pump system? It seems to follow that but not always.
  5. twozs
    8,782
    160
    Aug 5, 1999
    hopewell jct ny
    it doesn't have anything to do with what type of transmission . TCS will have a plug on the transmission to let the system know it's in high gear . TCS limits the amount of spark advance in high or drive gear under a predetermined temperature . once the coolant (or ambient temp ) is up to temp the system is disabled . so the system would need to know " high gear " on the transmission ..... hence the plug ...
  6. twozs
    8,782
    160
    Aug 5, 1999
    hopewell jct ny
    well all i can answer for is 1973 and ..... NO TCS on L65 with auto trans .. air pump YES . its in the assembly manual though if you have a 72 .
  7. lapedr
    524
    Jan 28, 2003
    Pembroke, GA
    No air pump thx everyone
  8. twozs
    8,782
    160
    Aug 5, 1999
    hopewell jct ny
    who said that . 4 bbl motors had air pumps
  9. lapedr
    524
    Jan 28, 2003
    Pembroke, GA
    There is a what looks like a pipe plug near the fill tube on the trans isnt this for band adjustment though?
  10. 70lt1z28
    2,475
    365
    Oct 3, 1999
    Here is an image of a turbo 350 with the TCS switch:
    Looks like it is right in front of the dipstick tube.
