Deer slayer 81
Discussion in 'Project Progress' started by 80sz, Oct 14, 2016.
  1. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    Thats what I was thinking. Go as far as I can. Laying filler and prep is the majority of the process. If i can get it lined up better Ill be happy for now. Wanna do motor but my on loan lift had to leave and just when I was going to use it. Coming back few weeks tho and going in for a revamp
  2. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    F555A3D8-81C3-41FA-B65E-1614807457F4.jpeg Got new spoilers on. New repos from oer. The middle piece spot on. A perfect repo. The sides not so much. They flares dont overlap as much as originals did. 1/4” compared to 1 .5” on the bottom. I dont know why repo parts arent exactly the same. They always seem to be off somewhere. I also had to reglue the stud style mounts on side flares. Jb weld for plastic worked great and really holds well. They spun loose after few trial fittings. I like the oe style better with the strap and studs bracket but that was anouther mod If I was going to use them.
  3. Bandit723
    Bandit723 Veteran Member
    2,260
    262
    Oct 1, 2016
    Waupaca WI
    Looking good...was wondering on how well the OER spoilers fit.
  4. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    They are pretty good. Had to drill a few holes for fender screws and brackets but fit like oe except for the flare overlap which shouldnt be a problem. You can almost butt them together for a flat look if wanted.
  5. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    38CA2C1E-0C36-4977-8C45-DBB1C9D1C38F.jpeg Got motor in today for a teardown. Decided I want motor in before I get painted. Its so close with the long nose in a 81 for engine hoist and the hood on and off is a challenge.
  6. Zspoiler
    Zspoiler Veteran Member
    2,024
    100
    May 6, 2012
    Federal Way, Washington
    You think you have issues setting an engine in a 1981 Camaro. My 1979 Z-28 RS has an Fibermotive IMSA nose on mine .I had to take it off to get the engine hoist to fit.But is sure nice to have a new engine in the car.It feels like Christmas .Good luck to you . 130044932860518017_26257430996_o (1).jpg
    80sz likes this.
  7. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    Thx . Its a tight fit with spoilers yours is extra tight. Cant wait for result of teardown. Nervous a bit
  8. Zspoiler
    2,024
    100
    May 6, 2012
    Just take your time with it.,Remember its a hobby and its supposed to be fun.
  9. WASyL
    WASyL LS1 Bandit
    20
    16
    Nov 9, 2013
    Warsaw, Poland
    Why won't You install engine from a side, it is same easy and dont bother about front spoiler/numera as fender is not that far.
    best regards
  10. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    I did think about a side install. I plan on bolting up transmission to motor Think fronts only way together.
